Roborock F25 Combo Series
All-Rounded, Ready Everywhere
No Place Out of Reach
Smart Wet-and-Dry Cleaning
Spotless with a Single Stroke
JawScrapers™
Complete Clean
Stays Clean and Ready to Roll
Seamless and Upgraded
Maneuverability
Intelligent App and
Voice Alerts
Tick, Tack, Switch.
One Core “Beats” for All
With a detachable power unit compatible with both bodies and three interchangeable brush heads, your machine seamlessly transforms into a wet-and-dry vacuum, a cordless stick vacuum, or a dust mite controller.
99.99%1
Bacteria Removal Rate
99.99%2
Mite Removal Rate
Not Just the Floor, But Everywhere
Wet-And-Dry Vacuum Cleaner
Mop away both wet and dry waste
Cordless Stick Vacuum
Dust removal with powerful, loss-free suction3
Dust Mite Controller
Meticulous care tailored for dust-mite sufferers4
Cleaning Crevices
Crevice cleaning brush designed for furniture gaps and window edges
Reaching Edges
Suctioning dust from household high spaces with extension baton
Sticky, Even Hairy Mess?
Make It No Mess.
99.99 %6
99.99 %6
Spend less time cleaning and more time living. With 20,0005 Pa suction and a 450 RPM cleaning frequency, the Roborock F25 Combo Series delivers spotless results in a single stroke.
Cleaning Strokes / min
20,0009 Pa
Suction Power
>20 N8
Downward Cleaning Pressure
<1mm12
Edge-to-Edge Cleaning
<1mm12
With a 60-minute battery life under Eco Mode, it ensures uninterrupted cleaning sessions, covering up to 410 sqm (4,413 sqft) before needing a recharge. *
60 min10
Battery Life under Eco Mode
410 sqm11(4,413 sqft)
Cleaning Area per Charge
JawScrapers™ Roller
Designed for Lasting Shine
0%13
Tangle Rate
FlatReach 2.0
12.5cm
Power through tight spaces with a 12.5 cm14 flat design that keeps full suction at 0°. Its ultra-low profile reaches every corner, leaving no dust behind.
Auto Detergent Dispenser
Smarter for Superior Cleaning
Enjoy up to 30 days15 of cleaning with a single detergent refill, as the auto dispenser precisely releases detergent as needed. *
*Available on Roborock F25 ACE Combo.
Moves as You Move
Small Tweak, Big Improvement
90 °C16
5 min
Fast Drying
99.99 %17
Multiple Stages
Separation System
99.99 %17
Multiple Stages
Separation System
Intuitive to Use,
Voice Alert
Auto
Cleaning Rollers
Empty the dirty water tank
Auto
Cleaning Rollers
One-Touch App Customization*
Mighty Suction,
Dust-Free Living
Sweep Dust Away in an Instant
Powerful suction paired with a unique adaptive brush, deeply cleans floors and carpets, leaving them spotless and refreshed.
120,000 RPM18
High-Speed Motor
25,000 Pa19
Suction Power
Green Light Illumination*
Shine the Light on Hidden Dust
Emitted from the brush head, the green light reveals dust and fine particles which are barely noticeable in natural light on the floor.
9-Cone Cyclonic Technology
Multi-Layer Filtration,
Consistently Anti-Clogging
Powerful cyclonic forces combined with a micron-level five-layer filtration system separate dust particles 8 times smaller than PM2.5, preventing filter clogging and dust pollution.
Removal Rate of 0.3 μm Dust20
5-layer Noise Reduction System
Free From Noisy Interference
≤73dB(A)21
Under Eco Mode
5
Zero Hair Entanglement
0%22hair tangle rate with unique adaptive brush*
Click, Drop, Clean
One-click dustbin release for dust convenient disposal and thorough interior cleaning.
0 0
Product Comparison23
5-in-1 Combo
Self-Washing & Drying
Voice Alert
App Customization
Weight (Wet & Dry Vacuum Cleaner)
4.7kg (10.4 lbs)
Dimensions (with dock)
352 * 316 * 1157mm
(13.9 * 12.4 * 45.6 inches)
Dirty Water Tank
720 ml
Detergent Tank
100 ml
Clean Water Tank
740 ml
Weight (Cordless Stick Vacuum)
1.7kg (3.7 lbs)
Multi-Surface Brush
Motorized Mini Brush
2-in-1 Cleaning Brush
Stick Vacuum & Brush Head Storage Stand
Maximum Suction Power
Wet & Dry Cleaner: 20,000Pa
Stick Vacuum:25,000Pa
Dust Capacity
560ml
Battery Life
Wet & Dry Cleaner: 60min (Eco Mode)
Stick Vacuum: 65min (Eco Mode with 2-in-1 cleaning head on)
5-in-1 Combo
Voice Alert
App Customization
4.7kg (10.4 lbs)
352 * 316 * 1157mm
Dirty Water Tank
720 ml
Detergent Tank
100 ml
Clean Water Tank
740 ml
1.7kg (3.7 lbs)
Multi-Surface Brush
Dust Capacity
560ml
Battery Life
1. Based on testing carried out by TÜV SÜD on Staphylococcus aureus, Candida albicans and Escherichia coli under default cleaning mode, over 99.99% of bacteria on the floor are effectively removed. Report No.: 704012409452-00. Actual results may vary according to the home environment.
2. Based on testing carried out by SGS lab, the bed brush removes mites up to 99.99% of mites under the test conditions. Report No.: DSS_SHES241102212771. Actual results may vary depending on the home environment.
3. Based on testing carried out by SGS lab, when the dust collector is continuously discharged with load, it can still maintain a constant suction power. Report No.: SHES241102211271. According to the standard QB/T1562-2014, Chapter 5.8 stipulates that “the difference between the test value and the stated value should not be greater than 3%.” When the test result of the sample is less than 3%, it can be stated that the suction loss of this product is 0%.
4. Based on testing carried out by SGS lab, the bed brush removes mites up to 99.99% of mites under the test conditions. Report No.: DSS_SHES241102212771. Actual results may vary depending on the home environment.
5. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021/5.11 standards.Actual results may vary depending on environmental factors.
6. Based on testing carried out by TÜV SÜD on Staphylococcus aureus, Candida albicans and Escherichia coli under default cleaning mode, over 99.99% of bacteria on the floor are effectively removed. Report No.: 704012406928-00. Actual results may vary according to the home environment.
8. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
10.Based on internal testing carried out by the manufacturer under Eco mode.
11.Based on internal testing carried out by the manufacturer under Eco mode.
12.Based on internal testing. Actual results may vary depending on environmental factors.
13.Data sourced from SGS and Roborock’s internal testing. In the SGS testing environment, the hair tangling rate of the floor washer was 0% across all four operation modes. In the Roborock internal testing environment, the hair tangling rate was also 0% when operating with 200 strands of 30cm dry and wet long hair. Actual results may vary depending on environmental factors.
14.Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors
15.Based on internal testing carried out by the manufacturer. After fully filling the cleaning solution tank, it can provide up to 30 days of usage without needing a refill, based on once-daily usage in a test environment. Actual usage may vary depending on environmental factors.
16.Based on internal testing. The self-washing temperature refers to the temperature of the hot air outlet blowing over the water, not the temperature of the water itself. Actual results may vary depending on environmental factors.
17.Based on testing carried out by TUV SÜD on Staphylococcus aureus, Candida albicans and Escherichia coli under default self-cleaning mode, over 99.99% of bacteria on the roller are effectively removed. Report No.: 704012409452-00. Actual results may vary according to the home environment.
18.Based on third-party laboratory testing. Actual results may vary depending on environmental factors.
19.Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021/5.11 standards. The maximum suction reaches up to 120 AW, which generates a suction power up to 25,000 Pa. Actual results may vary depending on environmental factors.
20.Based on testing carried out by TÜV Rheinland. The vacuum cleaner has a filtration efficiency of up to 99.99% for particles as small as 0.3μm under the test environment. Report No.: CN24W1OK001. Actual results may vary according to the home environment.
21.Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
22.Based on testing carried out by TÜV NUD, the average hair removal rate reaches 100.00% and leave 0 hair entanglement on the brush surface. Report No.: 704012409503-00. Actual results may vary according to the home environment.
23.Due to differences in measurement methods and usage environments, the actual data may vary from the values indicated above. Please refer to the physical products for accurate information.
