Flex Your Clean
Buy Now
FlatReach Technology: Reaches Every Nook, Even Under Low Furniture
DirTect: Automatically Adapts Cleaning and Self-Cleaning Performance
One-Stroke Wet & Dry Cleaning
With DirTect adaptive cleaning capability, Roborock Flexi Lite adjusts its cleaning power according to dirt levels on the floor, ensuring a thorough and time-saving cleaning experience. When cleaned at the base, DirTect checks if your roller has been cleaned effectively and switches to Deep Clean mode if it detects that the roller is still dirty after washing.
Always Fresh, Always Clean
Incorporating Roborock’s automatic self-drying & cleaning technology for wet-dry vacuums, Roborock Flexi Lite self-cleans with a roller scrape and water spray module, ensuring a sparkling clean result while cleaning your floor.
122°F
60
min
Auto Brush-Drying
60 min
50°C/122°F
Auto Brush-Drying
Hot Air
With Roborock Flexi Lite’s hot air self-drying feature, the roller is being scraped and washed in two directions with water, complemented by the flow of 50℃ (122℉) heated air, guaranteeing a hygiene and odor-free experience in an hour.
6inch3
Flexibility is the Key
Roborock Flexi Lite features FlatReach technology for thorough cleaning under low furniture, leaving no place for dirt to hide, ensuring a spotless clean.
Edge Cleaning
Roborock Flexi Lite easily reaches edges and corners with side margin of less than 1mm (1/8inch)4.
All in Reach, All in Sound
Auto
Cleaning rollers
Empty the dirty water tank
Lightweight Design
Weighing only 4kg (8.8lbs), Roborock Flexi Lite makes it easy to clean up messes without lugging around a heavy vacuum cleaner from room to room.
4kg
Cleaning That Lasts
Long-Lasting Cleanups
620ml
Clean Tank size
40min
Battery Life
400ml
Dirty Tank Size
STAY TUNED!
Roborock Flexi Pro Roborock Flexi Roborock Flexi Lite
Flexi-Pro Flexi Flexi-Lite
Up to 50 min Battery Life
Up to 40 min Battery Life
30 min Auto Brush-Drying
60 min Auto Brush-Drying
5 kg Weight
4.7 kg Weight
4 kg Weight
730 ml Clean Water Tank Size
620 ml Clean Water Tank Size
450 ml Dirty Tank Size
400 ml Dirty Tank Size
Double Edges Cleaning Design
Single Side Edge Cleaning
Hot Air Self-Drying
Hot Air Self-Drying
Hot Air Self-Drying
Hot Water Self-Washing
Standard Self-Washing
SlideTech Adaptive Wheels
Built-in Headlight
App Compatibility
App Compatibility
Flexi-Pro
Roborock Flexi Pro
Flexi
Roborock Flexi
Flexi-Lite
Roborock Flexi Lite
5 kg Weight
Hot Air Self-Drying
Built-in Headlight
App Compatibility
4.7 kg Weight
Hot Air Self-Drying
App Compatibility
4 kg Weight
Hot Air Self-Drying
