Roborock QR 798
Multifunctional Dock
Hands-Off, Hassle-Free
Mop Self-Washing
Self-Drying
Auto Tank Refilling
Detachable Dock Base
Off-Peak Charging
Mop Self-Washing
3-Stage
Dynamic Cleaning Process
Self-Drying
Room-temperature air drying keeps both the mops and dock fresh, preventing odors and maintaining a hygienic environment, so your home stays as clean as it looks.
45dB
Low Drying Noise3
The dock’s dust bag automatically empties the robot’s dustbin, letting you go up to 7-9 weeks without manual emptying, giving you long-term convenience. 4
65 days
without Manual Emptying5
99.90%
Pollen Filtration Rate6
10000Pa HyperForce® Suction1
Deep Clean, Effortlessly
HyperForce® Suction
Experience this veritable cleaning powerhouse with its 10000Pa HyperForce® suction. Whether it's hard floors or carpets, it proficiently extracts deeply embedded dirt and dust, guaranteeing a spotless clean with every use.
Less Tangle. Less Trouble.
Anti-Tangle Side Brush
Hair Tangling7
All-Rubber Main Brush
Dual Spinning Mops
Mop Like a Pro
200RPM
Maximum Rotating Speed8
10mm
Mop Lifting9
30 Levels of
Water Flow Options
See, Sense, and Steer Clear
Smarter Than You'd Imagine
PreciSense LiDAR Navigation
Scans quickly to know your home environment and creates detailed maps to find an optimal route to clean your home.
6x Faster
Quick Mapping10
3D
Map Display
Multi-level
Mapping System
Tap. Tap. Clean2
roborock app tap tap clean easy to use
Roborock SmartPlan
Powered by AI, the Roborock SmartPlan is a game-changer. With just a tap on the App, you can relax and let the robot take over. Based on the analyzed environment, it will automatically determine the optimal cleaning sequence and method.
Temporary Cleaning
Custom Routines
Broadly Compatible with
Third-Party Voice
Control Supported
Fully charged
After Meals
Launcher Widgets
Apple Watch
Roborock QR 798
350*353*96.5mm
340*487*519mm
Roborock QR 798
Roborock Qrevo 5AE
Anti-Tangle Design
FlexiArm Design
Suction Power
Main Brush
Obstacle Avoidance
Docking System
10000Pa Extreme Suction
Dual Anti-Tangle System
FlexiArm Mop
12000Pa Extreme Suction
DuoDivide Main Brush
STAY TUNED IN!
1. Based on internal testing carried out by the manufacturer according to IEC 62885-2:2021 / 5.11 standards, using Max+ mode with a full battery, the maximum suction power can be up to 10,000 Pa. Actual results may vary due to environmental factors. Suction power values may vary by country or region.
3. Based on internal testing carried out by the manufacturer, the noise level when drying is as low as 45dB in a semi-anechoic chamber. Actual noise levels may vary due to environmental factors.
4. Based on Roborock internal testing. Actual performance may vary depending on home environment, cleanliness level, user habits, and other factors.
5. Based on internal testing carried out by the manufacturer. The actual emptying interval will depend on user habits and environmental factors.
6. Certification No.PT/23/GEN/0046 by SGS (product code name:RRW0PEP). Actual results may vary depending on usage conditions.
7. Certified No.PT/24/GEN/0454/1 by SGS (product code name:RRW0PEP). Actual results may vary according to the home environment.
8. Based on internal testing carried out by the manufacturer, when selecting extreme water flow in custom mode, the mops can spin at a maximum speed of 200RPM.
9. Based on internal testing carried out by the manufacturer, the mop modules can be lifted up to 10mm. Actual results may vary depending on environmental factors.
