Hair tangles? No worries. Equipped with two parallel short bristle rollers and spiral blades, the DuoDivide Brush works in harmony to deftly direct hair toward the central dustbin inlet. It prevents tangles and clogging, ensuring that your floors are left impeccably clean without hair.
Hair Tangling3100%
Hair Removal4
Hair Tangling5
HyperForce SuctionExperience this veritable cleaning powerhouse with its 18,500Pa HyperForce Suction. Whether it's hard floors or carpets, it proficiently extracts deeply embedded dirt and dust, guaranteeing a spotless clean with every use.
1.85mm
Along the Edge698.80%
Edge Coverage6
200RPM
Maximum Rotating Speed7
10mm
Mop Lifting8
30 Levels of
Water Flow OptionsEquipped with dual liftable spinning mops, the robot tackles stubborn stains on hard floors. Plus, when it detects carpets, the mops automatically lift to keep them dry, ensuring a seamless clean.
Effortlessly lift oil stains from mops with 75°C hot water9, ideal for kitchen and dining areas, while also saving time and water. The hot water effectively removes over 99.99% of bacteria on the spinning mops10.
75°C
Hot Water Washing975°C hot water effectively removes stubborn stains and other dirt, saving time and water, while also disinfecting, to ensure that the mops are clean for an improved mopping experience9.
45°C
Warm Air1245dB
Low Drying Noise13The dock’s dust bag automatically empties the robot’s dustbin, letting you go up to 7-9 weeks without manual emptying, giving you long-term convenience.14
65 days
without Manual Emptying1599.90%
Pollen Filtration Rate16
Fully charged
After Meals
Roborock Qrevo C Pro
350*353*96.5mm
340*487*519mm
Roborock Qrevo S
2. Software user interface and functionalities may vary with software version updates. Actual software features and user interface are subject to the latest software version.
9. Based on internal testing carried out by the manufacturer. The water temperature at the hot water outlet of the dock can reach up to 75°C. Actual results may vary depending on usage conditions such as environmental temperature.
10.Based on testing carried out by TUV Rheinland. Effectively removes 99.99% of Staphylococcus aureus and Escherichia coli from the mop after self-cleaning. Certification ID: 0000088666. Actual results may vary depending on usage conditions.
11.Compared to the Roborock Q7 Max. Based on internal testing carried out by the manufacturer. Actual results may vary according to the home environment.
12.Based on internal testing carried out by the manufacturer, the air temperature around the mop can be heated up to 45°C during drying under 25°C room temperature. The actual results may vary according to the home environment.
13.Based on internal testing carried out by the manufacturer, the noise level when drying is as low as 45dB in a semi-anechoic chamber. Actual noise levels may vary due to environmental factors.
14.Based on Roborock internal testing. Actual performance may vary depending on home environment, cleanliness level, user habits, and other factors.
15.Based on internal testing carried out by the manufacturer. The actual emptying interval will depend on user habits and environmental factors.
16.Certification No.PT/23/GEN/0046 by SGS (product code name:RRW0PEP). Actual results may vary depending on usage conditions.
