Saros 20 Sonic
Beyond Detail. Beyond Clean.
Buy Now
Driven by next-generation vibrating mopping, Saros 20 Sonic delivers deep, precise cleaning while keeping floors streak-minimized. It glides effortlessly over high thresholds and plush carpets, and with every wash, the upgraded RockDock restores your mop to peak performance—keeping your home effortlessly immaculate.
Elevated Clean, Powered by Vibration
VibraRise 5.0
VibraRise 5.0
VibraRise 5.0 Mopping System
Vibrate, Extend, Perfect.
VibraRise 5.0
The VibraRise 5.0's extendable mop head presses into edges, unlocking a larger edge-to-corner cleaning area for a thorough clean without scratching walls⁴. Driven by an advanced, independent-motor system, it combines 14N of downward pressure⁵ with 4000 sonic vibrations/min for powerful scrubbing, all while ensuring a quieter and more peaceful clean.
27% Larger⁶
Mop Vibrating Area for Corner
1.75X
Boosted Mopping Pressure⁵
0mm
Along the Edge⁴
4000
Vibrations/min⁷
27% Larger⁶
1.75X
0mm
Along the Edge⁴
4000
Vibrations/min⁷
Extends to Clean Further
The single extendable mop reaches corners better than traditional multi-pad systems and eliminates mopping gaps between pads, ensuring a cleaner edge-to-edge finish.
Auto-Detach. Carpets Protected.
When vacuum-only or carpet-first modes are activated, the mop detaches automatically to prevent moisture transfer, keeping your carpets dry and protected.
Streak-Minimized Cleaning
The VibraRise 5.0 mopping system distributes water evenly across the mop, minimizing streaks and spiral marks. Every pass delivers a smooth, consistent finish—even along edges and corners.
Dial In Your Clean
Take full control with independent water and vibration settings in your app for a truly tailored clean.
Stains on hardwood?
Use minimal water to protect floors, while intensifying vibration to tackle the spot.
Greasy kitchen mess?
Blast through tough grime with with ramped up water flow and vibration.
Now you hold the power to flawlessly tackle every cleaning challenge in your home.
36,000 Pa HyperForce Motor
Demand Deep-Cleaning Excellence
36,000 Pa
Max Digital Motor Power¹
Dual Anti-Tangle System
Tangle-Free Cleaning, Guaranteed.
Hair? Gone. The innovative DuoDivide Main Brush and FlexiArm Arc Side Brush are engineered to prevent tangles from strands up to 40 cm long. Enjoy uninterrupted cleaning with a system designed to stay free of hair wrap, cycle after cycle.
Hair Tangling Rate⁸
Hair Removal Rate⁹
Hair Tangling Rate¹⁰
Liftable Brush and Mops
Vacuum Only
Mop Mode
Clean Carpet
Mops detached
Main brush lowered
Main brush lifted
Deeply Clean Carpet First
Usual Cleaning Path
Mop lifted / Main brush stabilized
Vacuum Only
Mops detached
Main brush lowered
Mop Mode
Main brush lifted
Clean Carpet
① Deeply Clean Carpet First
Mop detached
Chassis lifted
② Usual Cleaning Path
Mop lifted
The Unbound Flow.
AdaptiLift Chassis 3.0
Climbs, Lifts, and Cleans Like Never Before.
Effortlessly Conquers 8.8 cm Obstacles
4.5 cm+4.3 cm
Engineered to go where others can't. Inspired by previous innovations in mobility, our next-gen AdaptiLift Chassis 3.0 system features a climbing arm that orchestrates a lift-and-climb maneuver over 8.8 cm double-layer thresholds—a significant leap forward. With unwavering confidence, it delivers a seamless, uninterrupted whole-home clean.
Industry-First Dynamic Cleaning for Up to 3 cm Carpets
30% Higher¹²
Dust Pick-Up Rate on Long-Pile Carpets
Experience industry-first¹¹ dynamic chassis elevation with an omni-directional wheel system. The robot intelligently adjusts its height to maintain optimal suction on carpets up to 3 cm³, ensuring deep, consistent cleaning across varying pile heights—finally delivering true carpet-cleaning performance*.
When Deep Carpet Cleaning is enabled, the main brush remains in a stable downward position on the second carpet pass, boosting cleaning efficiency compared to its usual floating motion*.
Prevent Getting Stuck
Low-Clearance Performance with RetractSense Navigation System
Sees and Cleans Even in Tight Spaces
With a minimum clearance of just 7.95¹³ cm, enabled by a retractable LDS and a class-leading slim profile¹⁴, the robot moves smoothly through low-clearance areas while maintaining accurate mapping. The RetractSense Navigation System supports consistent movement and coverage, ensuring effective cleaning even in confined spaces¹⁵.
In Open Spaces
Under Furniture
FlexiArm Technology
Reaches Toe Kicks. Cleans Every Edge.
Roborock's exclusive FlexiArm Arc Side Brush intelligently extends to clean along walls and corners. Enhanced by a precision algorithm, it precisely targets and sweeps debris from toe-kick areas—ensuring complete coverage across your home's varied floors.
Edge and Corner Sweeping¹⁶
Down to 2 cm
Toe-Kick Area Cleaning¹⁷
The Dock That Thinks, Cares
Brand New RockDock
Independent Mop-Washing System
3-Min
Saves Each Cycle¹⁸
The dock independently cleans detached mop pad while the robot is out vacuuming, so a freshly washed mop is ready the moment the robot returns. Seamless and automatic transitions keep your cleaning schedule uninterrupted.
100°C Hot-Water Mop Washing
Our Brand New RockDock cleans mop pads with up to 100°C near-boiling water¹⁹, blasting away grease, dirt, and residue. Every wash refreshes pads thoroughly, leaving floors cleaner and more hygienic.
Up to 100°C
Hot-Water Mop Washing¹⁹
Bacteria Removal Rate²⁰
55°C Warm Air for Full Dust-Path Drying
The dock's 55°C²¹ warm-air system actively dries the dust pathway—including the dust bag and evacuation ducts, reducing mold and odors for a fresher, more hygienic dock.
55°C Warm Air for Mop Drying
Dries the mops and dock base thoroughly with 55°C²¹ of warm air, preventing the growth of mold and unpleasant odors.
The dock base stays hygienic thanks to up to 100°C¹⁹ hot water and the self-cleaning module, minimizing the need for manual maintenance.
Auto Detergent Dispenser
Equipped with an auto detergent dispenser, the dock automatically adds cleaning solution, delivering a deeper, effortless mop clean.
Warm Water Auto-Refilling
150-min Fast Charging
Fully charges the 6400 mAh battery in just 150 minutes²². Its intelligent system adjusts charging based on the remaining cleaning area, getting your robot back to work faster without waiting for a full charge.
Allows for up to 65 days²³ without manual emptying.
Perception That Guides Every Move
Equipped with triple structured light, an RGB camera, and VertiBeam lateral structured light, the robot maps its environment in exceptional detail. It detects obstacles near and far, navigating smoothly and intelligently with minimal blind spots and precise control.
300+
Types of Objects Recognized²⁴
Sees Beyond the Side
Cleans Behind Curtains
The VertiBeam lateral structured light expands the robot’s field of view, detecting slim and low objects along walls and furniture with precision. It reacts instantly to avoid obstacles such as cables or chair legs, ensuring safer and smoother navigation in every corner.
With manual curtain marking in the app, the robot identifies and cleans behind curtains, and soft partitions. Hidden areas are covered automatically—no need to lift, move, or adjust anything, for a more complete and effortless clean.
Your Privacy, Our Priority
Roborock adheres to strict global data privacy standards, processing all visual data securely on-device to keep your home as private as it is clean.
Roborock APP
The Brain Behind Every Clean
Carpet Cleaning
Want to deep clean carpets or skip them entirely? One tap²⁵ is all it takes. Your robot adapts automatically—boosting suction on carpets with the mop lifted, or following precise edge-cleaning paths to avoid rugs and keep them dry. You're in control of every room, every rug, every time.
Roborock SmartPlan 3.0
Pet-Friendly Intelligence
Closer to Your Furry Friends
Automatic Pet Recognition
Pet Snaps
Search for the Pet
Video Call & Cruise
Pet Snaps
Search for the Pet
Video Call & Cruise
Everyday Features
Tailored Mopping Vibration & Water Flow
Take full control of water flow and vibration settings in your app for a truly customized clean.
Stain-Target AI Cleaning
Automatic Re-Cleaning for Missed Spots
Built-in Voice Assistant
Third-Party Control
Key Specs
Saros 20 Sonic
Saros 20 Sonic
350 x 353 x 79.8 mm
440 x 409 x 470 mm
4. Based on internal testing carried out by the manufacturer. The mop adopts a Protruding-Fiber Design with elastic support, allowing the mop fibers to reach and clean along edges while preventing scratching the walls. Actual results may vary depending on environmental factors.
5. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors. Boosted mopping pressure result is derived from the comparison with Saros 10.
6. Based on internal testing conducted by the manufacturer, compared with previous Roborock vibrating robot vacuum cleaners. Actual results may vary depending on environmental factors.
8. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
11. This feature is powered by Roborock’s AdaptiLift Chassis—the industry’s first mass-produced liftable chassis system with three-wheel control, launched in Q3 2024. The dynamic carpet-cleaning capability was officially introduced in Q3 2025.
12. Based on Roborock internal testing using Max+ mode. Compared to the performance on the 2cm long-pile carpets of previous Roborock vacuum robots. Actual results may vary according to the home environment.
13. The body height of the robot vacuum is 7.98 cm. Due to slight vertical flexibility in the front structural components, the robot may achieve limited passive compression when entering low-clearance spaces, allowing access down to 7.95 cm. However, please note that scraping may occur. Actual performance may vary depending on environmental conditions.
14. Based on research conducted by Roborock, as of November 2025, the Saros 20 Sonic is the thinnest model among Roborock's vacuum robots.
15. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
16. Based on internal testing conducted by the manufacturer using side brush for edge and inside-corner sweeping performance. Actual coverage and distance may vary depending on the home environment.
18. Based on internal testing carried out by the manufacturer. 'Each cycle' refers to the robot’s sweep-then-mop process for a specific area during a cleaning operation. Actual results may vary depending on environmental factors.
19. Based on internal testing carried out by the manufacturer. The water at the clean water dispensers of the dock can be heated up to 100°C (212°F) under standard atmospheric pressure (1 atm, 101.3 kPa) at room temperature. Actual temperatures may vary depending on environmental conditions such as altitude and atmospheric pressure.
20. Based on testing carried out by TÜV Rheinland on Escherichia coli and Staphylococcus aureus under default self-cleaning mode, over 99.99% of bacteria on the mop are effectively removed. Certification ID: 0000087672. Actual results may vary according to the home environment.
21. Based on internal testing carried out by the manufacturer, the air at the base’s outlet during drying can be heated up to 55°C under standard room temperature. Actual temperatures may vary due to environmental factors.
22. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
23. Based on internal testing carried out by the manufacturer. Actual results may vary depending on environmental factors.
24. Based on internal testing carried out by the manufacturer, the robot vacuum can see and bypass objects down to as small as 3 cm wide and 3 cm tall. Recognition accuracy may vary depending on environmental factors.
25. These carpet cleaning settings must be manually enabled and selected in the Roborock app. This feature is applicable to household carpets with pile heights of 3 cm or below, which covers the majority of carpets used in typical homes.
